Originally Posted by cobish
Greg,
Your ETA is great, back calculating HP from ETA about 441 to rear wheels and maybe 2850 pounds for car and driver. What are the size of jets to otain this ETA? Good show, congrats.
John
Off the top of my head the secondary jets for the last/best pass were 95 and 90 for the primary.
I think the car is about 2550 lbs with me in it and low fuel. I don't launch the car, but start a bit over idle, so time is about .4 slower that potential. Use MPH for HP calculator in this link.
http://www.pro-system.com/calc.html
The pass should come out about 430 to wheels uncorrected. Correct that to sea level and it's around 463. I think it would put down about the same on the load bearing Dynodynamics were I usually go. I'd like to put the car on a Dynojet for some bragging numbers that are a little higher.
If you want to sea level correct here's a link.
http://www.modulardepot.com/density.php
Conditions were
70F
25% humidity
30.0 inHg
1250 ft. elevation
or use
70F
25% humidity
28.7 inHg
0 ft elevation
It comes out about 2200 ft DA, but I called it 2100 DA to be safe.
