  #23 (permalink)
Old 12-16-2006, 06:58 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Mark
Yes that is me adjusting the wing......and those are some great shots of the car........ do you have one when we had it on jack stands...???
And the set up Jamo is using is what we were using on CSX 4303 ..... Red .....
And it had oil coming out of the breather on the passenger side .....so we took the cap off of the catch can and put scotch brite over the hole and cable tied...... and it reduced the amount of oil coming out of the breather....... on the passenger side....... because that cap on the catch can only has a small vent hole.....
If you run the motor up in the 6500-7000 rpm's ....it's just pushing to much air..... and Gateway on the oval is a different issue....
Morris
Morris
