Richard:
Let me get this straight. I can leave the pipes on the car and put axle grease on the top of the slip ins, start the car and let it run down into the fittings as the engine is running. Once the fitting stop smoking I cut the engine off. If my fitting are larger than your specs (.015) then I may have to perform this procedure more than once. This will seal the pipes?
Thanks, Coach Mike
