Thread: Ignition system
Old 12-17-2006, 09:13 PM
speed racer's Avatar
speed racer speed racer is offline
Default unilite Mallory
I just installed the Unlite system. So sweet. I did not even have to remove the distributor to install. Bolts right in place of the dual points.I replace the coil with an other oil filled coil that is electronic and the wires with spiral core.So it looks old school but has all the advantages of electronic ignition system. If any one else is running points you should look into this system.You can convert your Mallory distributor for about $250.00.
James
