Old 12-18-2006, 10:02 PM
shelby racer's Avatar
shelby racer shelby racer is offline
Cobra Make, Engine: Shelby CSX4788 with a Dawkins performance 490 ci iron genesis block hydrualic roller
Default I guesss I am not clear
Thanks for the reply. The pedal has a shaft that comes out of the far end of the foot box with 3 holes in it vertically. I have the heim jointed shaft bolted to the lowest hole. The heim jointed shaft connects to a lever (with only 1 hole) that is connected to a shaft that travels from the foot box to the manifold. On this shaft there is another lever that has two holes and I have another heim jointed shaft that runs from the top hole of that lever to the carb (that only has 1 hole) to try to maximize the length / dergee arc traveled. 3 levers (two of which have multiple holes), 1 carb attatchment poiny, 2 heim jointed shafts, and 1 solid shaft running from the foot box to the manifold with 2 of the levers (one on each end. It is like an ERA set up. I hope we are on the same page now if I was not clear before. Thanks again
John(;-)
Racing, bull fighting and mountain climbing are the only true sports, everything else is just a game. - Hemmingway
