Thread: gasket
Old 12-19-2006, 04:48 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I made mine out of the same material from NAPA and it seems to be pretty good. I haven't put any miles on it to really test it though. I did the poor man's method and traced an outline on plywood then sandwiched the material between the wood and used a hole saw to cut the holes. Then I was able to trim the edges from the outside with a razor blade fairly easily.
