I went with 1/2 to 3/4 of an inch and aluminum tape inside to the edges. If that isn't enough you can cut it back further with a grinder. Try it a little before painting. The dryer and older the paint the less likely to be affected. Still ,letting the engine run prolonged periods without air moving around is asking for trouble. Are you concerned with movement or heat?
Mike H
