Old 12-19-2006, 01:58 PM
blykins blykins is offline
I've left engines on cradles for several months. There are some good tips for storage.....leave the rocker arms loose so there's no pressure on the valve springs....spray a little WD or fogging oil in the spark plug holes so the rings won't stick to the cylinder wall. Every week or so, it would be a good idea to spin the oil pump with a drill motor and turn the crank a couple turns.
I don't see problem at all with letting an engine sit though.
