Old 12-20-2006, 11:33 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
I've heard of MSD units failing within the first 30 milnutes of use. An article about small block tune in the last Second Strike newsletter talks about that too. I thought about changing the Accuspark unit in my SPF Cobra so I could have a rev limiter. Then, Pertronix came out with a digital rev limiter that you could add on, so I bought that. The Accuspark is extremely reliable, idles the 460 down to 600 RPM, and will rev that sucker without a miss up to 6000. (Well, that's where I set the limiter).
If you're starting from scratch, mybe the MSD distributor, 6AL ignition, and blaster coil would be a consideration.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
