Originally Posted by TKing
Don: Have you been to RT's web site at http://performanceunlimited.com/cobravalley/? The 1 wire deal seems okay, but I heard some people say the alternator warning light would not work and others were concerned about 100 or more amps going to the amp gauge. I need to do more research, but have other things to fix/modify on my car before I fix the low amperage problem.Tom
Tom yes I had checked RT's site and have an order in there for the 105HD Reactor alternator. The Lucas ammeter is rated at 50A should not be used with a high output alternator, and is rendered nonfunctioning anyway with a proper install of a single wire system as all the recommendations are to run a large gauge wire from the alternator output directly to the battery terminal on the solenoid, so this defeats the circuit through the ammeter. I have installed a Smiths voltmeter in mine and removed the ammeter. There is a way to retain the charge light function with a single wire alternator (requires a small added circuit I'm told) but I am in the processing of converting my red warning light to a low
oil pressure warning system which would be much more useful for me.
