Old 12-22-2006, 07:32 AM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
daydreaming about the day I'd know my Cobra well enough to want to test its peak performance against another driver
no one has ever won a drag race at idle. Build the engine so your torque curve starts at about 2800 and peaks at around 5000, depending on the engine platform you choose. Larger cube engines with their longer stroke will naturally make more torque in the lower ranges. Smaller short stroke engines have to be run to higher RPM's to develop their power. The lighter the car, the less engine you need to get the perforomance you're after. John
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
