Originally Posted by hi-tech cobra
Thanks tbirdz12,
Can you tell from the pics if the port job looks good. It looks like these will be the heads I go with after all (build budget). I have the single springs that came with the Ford Racing Valve train kit. What would be a good double spring upgrade?
Cant tell on the porting. Maybe someone else can. You should get valve springs that are compatible with your cam requirements. Some require higher spring pressures than others, depending on rpm range, ramp angle and more.
