Old 12-26-2006, 09:41 AM
TKing TKing is offline
Cobra Make, Engine: X Everett Morrison, X SPF 140, X SPF1823, currently SPF2778
Hi Don:
My question was for you. I thought the dash had to be removed to access the gauges. The backside of my dash is a maze of wires especially considering the addition of the radio and alarm system. I think I'l try removing the dash to replace the amp gauge with a voltmeter.
I also need to replace the gas pedal which will necessitate the removal of the steering column and to remove the column I must remove the dash and since the dash is out I will replace the amp gauge. It's amazing how little problems can cause a lot of work.
Thanks,
Tom
