Old 12-28-2006, 04:38 PM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
They just want to avoid liability when you build your motor and it comes apart, and the lawyer claims the torque wrench was not accurate enough.
I counted 13 warning signs on a dumpster the other day!
Do not worry, use it on everything. But first, find a friend with an expensive torque wrench and compare them at 75 and 100 ft-lbs. Then you can offset it a few pounds if it really is off by 4%.
Using a torque wrench on tires does not make it inaccurate. But dropping it on the floor will
My Craftsman torque wrench is almost 40 years old, and it was within 2 ft-lbs at 100 ft-lbs when I checked it last year.
Warren
