Thread: c6 questions
Old 12-29-2006, 08:01 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
I'd say that you would damge the tranny running it dry. The yoke splining should be the same, although they are not the same, for your purpose any one will do. I also believe that the manual trans ones are the same splining as well. That indicate sthat I feel you should install a yoke, although it is mainly a cleanliness issue....no fluid leakage. You also want to make sure that you run a line between the 2 oil cooler fittings, but a cooler isn't needed for your purpose.
WDZ
