Old 07-07-2001, 01:22 PM
Peeps Peeps is offline
Default Pictures Finally!
Here they are and again thank you for your patience.
Just a couple of things as you look at the Photos. The reason for the Rear Brake Calipers not being mounted is that I am in the process of Safety Wiring the rear end. Also as you look at the Engine Block it looks rusty. It isn't. It seems that here in California, the EPA has outlawed Hot Tanks for boiling out engine blocks because of the Chemicals. They now "Burn" the block and it comes out this Reddish color looking like rust, and also not in the photos are pics of all of the other parts (brackets etc.) for the engine but if you would like them please call and tell me.
Since I went to Trigo's, Shell Valley said that I needed to go to there shorter A-Arms otherwise the tires might rub on the Fender Well, so the photos you see have the new A-Arms and I have the older longer ones. I will be home all weekend if you have any questions.
Thanks - Peeps
My personal e-mail is 5peeps@gateway.net
Work e-mail john_peoples@sscsinc.com
Home # 831-626-1514
Work # 800-972-7727
http://members7.clubphoto.com/john404733
