Campy: By tail I mean the rear section of the body. When I put it on the frame without the trunk section, it sat on the tires. I'm not so much concerned about aligning the body, I guess I'm more concerned about picking something up off the ground into the fiberglass and into my a%%$.
So I guess you just have the fiberglass bottom between you and the frame. I'll continue to go that way for now.
The engine is a 427Side Oiler. You're right about those motor mounts. So far it looks like there are at least two completely different shaped motor mounts available for FEs. One will be about 2" higher than the other.
