Push Button Start Switch
Bob, I would like to install a push button start switch with a flip up ignition switch. I would like to use the keyed ignition switch as an on off switch.
The start procedure would be the following secquence: Turn the key to the on or run position. Use the push button start switch to crank over the engine. Flip up the remote ignition switch to turn on the ignition and start the engine.
How do I wire up the remote start switch and flip up ignition switch off the original keyed ignition switch?
The keyed ignition switch ia an AC Delco with Batt., AC., IGN., and Start terminals for an ERA FIA
 Snakebit
