Hello, I am from Austria,
maybe there is a good hint for You. Depends on the damage.
If it is just a smaller one, why not try to pull it out with modern technology. Here in Europe bodyshops use a tool which is glued to the dented surface.After glue is hardened, you can pull the sheet out, and afterwards break glued - on tool away. A small dent my remain, but this method can spare the nasty work of changing the tank.
best regards from Vienna
Thomas
