I went the non sb100 route for my first attempt. Used a C3AE block which was declared by the smog ref to be out of a 1963 galaxy. All I had to do was make the car pass 1963 smog requirements. Sealed breather system and PCV. No problem. Then came the trouble. You still have to meet the smog sniffer for that year motor. Timing for that motor was to be set to 5 deg BTDC and idle set to 500 rpm. No way I could pass the sniffer. Hell, I could barely keep it running with the cam I am using at that low of an rpm. Jetted as far down as I could go and just could'nt get it. My last resort if I did not get the SB100 title was to change my cam back to the stock version to pass the sniffer. I would have to change the cam back every two years to pass smog. Luckily I got the Sb100.
Another thing I learned; If you are using a ford FE motor and are not going to go the SB100 route, use a C4AE or older block. The C5AE was used up till 1972 in pick-ups. A not so pleasant Smog Ref will know this and make you comply with 1972 smog specs. In other words tons of smog equipment. I was told they are supposed to go with the last year that motor was used in.
