Old 01-05-2007, 09:29 PM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Michael and Jay, The slave pictured is pulling to the front. I did not end up with that set-up. The problem I had was the fork with the pivot on the passenger side, did not have enough travel to fully release the clutch. I ended up with a fork that pivots on the drivers side, and a similar slave pulling to the rear. I used a long adjusting rod to the fork, and a heim mounted to the frame at the other end.
I still have the parts in the picture if you want them.
Brad
