Originally Posted by Burgs
Michael and Jay, The slave pictured is pulling to the front. I did not end up with that set-up. The problem I had was the fork with the pivot on the passenger side, did not have enough travel to fully release the clutch. I ended up with a fork that pivots on the drivers side, and a similar slave pulling to the rear. I used a long adjusting rod to the fork, and a heim mounted to the frame at the other end.
I still have the parts in the picture if you want them.
Brad
Interesting... your new setup is what we used on Michael's car. I think he just needs to adjust his pedal though since it is over-extending the slave after clutch break-in.
Thanks for the info. Did you end up with a Wilwood slave?
