By far the best way to do this...
Is to find an old fashioned auto parts or brake and clutch supply and just purchase the straight lines already flared with tube nuts. Generally these are supplied in certain lengths, I found that by re-routing slightly you can generally use up the extra couple of inches by going around the long side of a bracket.
Using the highest quality 3/16" double flare manual tool I was able to get about 2 of 3 to fold nicely, with lesser tools it was worse and the tool usually broke. This was slow and painful, hence the suggestion above. The pre-made lines are usually
zinc plated steel, but that just makes the bending easier as well. Clear coating helps retain the shine.
