In the Jag setup you posted the orange arms are the bottom 'H' bars that act as the bottom w/bone & also control any twisting under braking/ acceleration. The black half shafts also act as the top wishbone & have shims where they bolt onto the side output shafts of the differential to adjust camber. The vertical pieces(4) of square steel tube are in the position that would normally be occupied by the coil over spring shock units(4). The gray tube above the diff unit is the fabricated mount to install the unit to the chassis. the gray piece underneath is a display stand.
With the exception of the 'E' type & 'S' type jags I think all other Jag rearend assy's have to be narrowed to fit within the std Cobra Body.
There are other rear axle assy's that can be adapted- 1989> 300zx Nissan, 1984> Corvette are a couple that spring to mind. The latest Ford T-bird/Mustang-Explorer could also be used. In Europe you have many cars that have IRS that could be used on a cost effective basis to you. BMW Mercedes Porsche 928( Yep I know its a combo trans diff unit, check out Rat Rod Russel's build in the scratch build section of this forum), He has used a late vette T/Axle, you could use a 928 to the same method. All comes down to what you feel you are capable of.
Check out the 9" IRS center section I have built for my own use in my gallery pics, does your school have casting/machining facilities, perhaps you could extend your class to do some of this work also.
cheers
Jac Mac
