Thread: 410 FE on Ebay
Old 01-07-2007, 07:31 AM
westcott cobra's Avatar
westcott cobra westcott cobra is offline
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
Default 410 FE on Ebay
Since a few weeks this auction is on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...8014627&rd=1,1
Any idea who is behind that?
How does it sound to you?
Please refer to the description not to the pic, its just an eye catcher
Here is a small extract from the parts list:
block--------------------428 service bored to fit
crank--------------------427 nodular steel machined to .010
rods---------------------hipo 390/427 ford (C6AE)
pistons-----------------forged sealed power
rings---------------------hastings moly .030
bearings----------------clevite 77 "H"
gaskets-----------------fel- pro
bolts----------------------arp rod bolts
camshaft----------------PBM 160324 300 duration 542 lift (some choice)
lifters---------------------hydraulic
timing chain------------cloyes double roller
pushrods----------------hardened
rockers------------------new rocker shafts
oil pump-----------------melling
heads--------------------ford (C6AE-6015-j) ported with hardened seats
valves--------------------stainless 2.09/1.65
timing cover-----------stock ford
oil pan--------------------stock early
valve covers-----------chrome early rounded
vibration damper-----stock ford
intake---------------------390 4 bbl cast
carburetor---------------holley
air cleaner--------------chrome
fuel pump---------------stock ford
hose----------------------2' connecting carb
distributor---------------ford duraspark II
cap, rotor---------------ford duraspark II
plugs---------------------motorcraft
coil------------------------motorcraft
plug wires--------------double silicone
ign module-------------wells F102
eng bolts---------------new kit
wire looms-------------chrome
I'm looking arround because I'd like to replace my Cleveland by an FE in the next 24 month.
Westcott
PS: I'm located in Germany !
Everything should be as simple as possible - but not simpler !!
