Old 01-07-2007, 09:12 AM
At higher rpm that would verify if the mechanical advance is working. You are only checking 'base' timing at idle speed. It's also possible your cam is retarded or advanced in relation to the crankshaft. Major restriction on the exhaust pipe(s), ie collapsed internally, plugged up in some way?
