Well let's start with a casualty report. Thurs. angle grinder died bought new cheap one (with the abuse they get from me good ones don't last much longer). Fri. belt sander blew a bearing, fixed it with parts from broken angle grinder
. Sun. melted hole in air hose will fix at work.
With everything going wrong I was still able to get my removable backbone finished and in the car. 12 bolts, tight fit, told ya I could it. I don't think I need to worry about another cross member with that cage bolted to the frame. Kind of ties the rear suspension together also should cut down on twist as well.
Patrick
There are lots of new pics in my gallery. I'm also going to post this on the trany cage thread as well.
