Thread: Hard to Start
Old 01-08-2007, 02:46 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by Excaliber
A friend of mine just bought a '30 roadster, 302 with a blower, really nice ride. Really hard to start, runs good if it does.
We found the starter was draining the battery voltage so low it wasn't making 'good spark' while cranking. The clue was: It WOULD start most times JUST when you left off the key and stopped trying to crank it! In that 'instant of time' THATS when it would fire up!
To test I rigged up a wire direct to the alternator battery terminal and touched the other end to the positive side of the coil WHILE he was cranking it over. The car started everytime and instantly! He will replace the Ford solenoid which, in his case, does NOT have the "I" terminal, only the "S" terminal. The "I" terminal gets wired directly to the positive side of the coil (depending on your ignition system) and provides the highest possible voltage while cranking.
FYI
We figure the car has been like this for YEARS and was probably a factor in the 'low price' he was able to buy the car for!
That's sounds more like a bad ignition switch to me. Either that, or the ignition power is not tied into the "start" pole of the switch. So the motor only catches JUST as you transition from start to run. Putting on your jumper wire, that just solidifies that you don't have any crank power to the ignition and when you now power it, it fires right up. Might want to check into that.
Of course, using the I pole of the solenoid would do the job as well, but I don't think you've got a low voltage issue, I think you have a no crank voltage issue.
Sal Mennella
