Max, check with Summit on the rims. You can probably get a set of 15" rims with the corrct backspacing (4.75" I think) for about $120. ETs should be around $180 each. My estimation is that you will gain .5 second with drag radial vs BFGs. Gotta get those 60' times down to the 1.75s area in order to get the best times of what your car is capable of.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
