Old 01-11-2007, 07:04 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
Default Heads
I would find out from Roush what type of pistons are in the motor. The AFR 205 probably will require piston notches. You might want to look at the 185's they have a 2.02 intake and a 1.60 exhaust. Also find out if your header will match the 205's if you use them. I know the AFR 165 and 185 have stock exhaust location (ie no raised port) not sure about 205's. If I was doing heads I'd do a matching cam also. You may want to just dyno tune what you have and drive it for a season and then upgrade. There may be some horsepower on the shelf. Good luck it sound like you have a fun ride.
Good luck
Dennis
