Old 01-12-2007, 12:36 PM
Manowar's Avatar
Manowar Manowar is offline
Default World Products Custom 302 blocks
FORD BUILDERS! A GREAT OPPORTUNITY TO BUY A SPECIAL BLOCK
World products has created a special Man O'War Windsor block known as the "C" Block, to allow major displacement in the 302, 8.2 deck size with 2.749¡± mains.
This block is a special casting with unique features. It allows strokes larger than 3.470 in this small package. It can do this because the oil pump boss has been cast in the 9.5 deck, 351 location which moves it out of the way of larger strokes. In fact, a 4.250¡± stroke will actually swing in the crankcase, however piston compression height precludes such extremes.
Further advantages are that with this combination, a 351 oil pump, drive rod, pan and distributor must be used.
All the other great World features are in this block. Features like priority main oiling, dry sump compatible, billet splayed four-bolt main caps and improved cooling jackets. This block also has the World exclusive six-bolt head attachment for boosted or nitrous oxide applications. It mates perfectly with World¡¯s six-bolt 10¢ª aluminum cylinder head.
Did we mention that this is the famous block design that won the 2006 Engine Masters Challenge?
These are brand-new, first quality blocks, and if you order now you get FREE FREIGHT!
Call the Sales guys at The Engine Shop and ask about part number 087121C to order now.
