MaSnake, you're on the ported source. I think the ones on the base plate are manifold vacuum.
Kennyb, vacuum advance is max when the engine is idling/cruising only if using manifold vacuum as the source...but vacuum advance is zero at idle if using ported vacuum.
Ken
