Old 01-14-2007, 09:19 PM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Distributor vacuum advance line should be attached to small port, usually located just beneath the primary fuel bowl on the passenger side.
Timing at 36 º at 2500 RPM and above with vacuum line disconnect at distributor.
I am not familiar with MSD. Could the 21 º bushing be "distributor degrees" which would be 42 º damper degrees of mechanical advance?
If you are having 50 degrees advance with vacuum line disconnected, I would switch bushing to a 10 degree unit (10 degrees distributor). That would be 20 degrees crank mechanical advance. With the 15 º initial timing, total would then be 35 º total.
Of course, check everything with timing light.
Good luck. Your 50 º+ could hurt the motor. Make that will hurt the motor if you add laughing gas.
Of course, if you are having 50 º with vacuum attached at a steady RPM, that is OK, and your miss is being caused by something else ... weak coil, bad plug wire(s), time for new spark plugs, etc.
Warren
