I want to fit an
oil tepreature sensor. The vdo sensor is brass as is the fitting it screws into. I was going to drill a hole in the sump and have the brass fitting welded into the sump. I have since learned that brass does not weld to steel. So I guess I now have to get a metal plate tapped and welded on. I have not drilled the hole in the sump yet. Before I start
do any of you brilliant people know of an easier way? am I missing something?
