Thread: Side pipes?
Old 01-18-2007, 07:04 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
May I suggest two things, if you are mounting your motor w/ standard mounts, use rubber hangers on your pipes and don't solid mount them. Two, solid mount your engine, or strap it to the frame to limit all movement. Also I noticed your sidepipes are for a big block. Generally the sidepipe tubes match the header size, (just an observation)
Tim
" It ain't no big deal"
