Old 01-18-2007, 07:43 PM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Oil or water temp gauge? I've replaced my oil temp gauge twice with no interference problems. I just looked at my instruments and the water gauge has less clearance from the steering column, so I'll bet that's your problem. For what it's worth, my approach would be to remove the steering wheel and slide the hub and turn signal ring up to allow enough clearance to pull the gauge. Easy to do - just pry off the center badge (use wood or plastic so you don't mar the aluminum), and then remove the 15/16 nut that holds everything on. I think at this point stuff can be slid forward on the steering column to give extra clearance for the gauge to be pulled. But since I've never done it, I may be leaving something out. Should be obvious once you get the wheel off.
Are you a member of SCOF? If so, be sure to ask there. If not, I highly recommend it. Click on "JOIN", left column:
http://performanceunlimited.com/scof/
And good luck with the new gauge.
Jerry
