Old 01-19-2007, 05:48 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Thats about it except you will probably need to change the front u-joint yoke on the drive shaft. That might entail cutting off the front of the shaft for a different end, but its a simple deal. when you move the crossmember/mount you may have to adjust the height also
When we changed Bob Browns Shell Valley we make a fixture to drill the frame rails so the cross member bolts were 90* frame material was hard, an angle drill is handy to have and use
Jerry
Jerry
