Old 01-21-2007, 06:23 PM
Rick Parker's Avatar
Default Read this
All Starters require clearance between the flywheel and the pinion gear while in static position. It would appear that this is lacking in your installation. I think the incorrect nose piece is being used in your application. .062 seems to be a common measurment.
http://www.powermastermotorsports.co...torqueShim.pdf
If you go to http://www.tiltonracing.com/content....ist2&id=31&m=s they have several illustrations of the nose pieces for their products. You can see various depths for different applications and you can get an idea of what must be accomplished.
Rick
