Old 01-21-2007, 08:53 PM
Tommy's Avatar
Tommy Tommy is offline
Sorry, no pictures but here's what I did. My E-M has a Richmond transmission and a pusher type slave cylinder. While laying under the car, I could see that the slave cylinder needed to be mounted about even with the front face of the scatter shield. As my slave cylinder had mounting holes perpendicular to the length of the cylinder, I realized an L-shaped bracket mounted to the scatter shield would work. I fabricated a bracket from a short lenth of angle iron with braces welded at each end to reduce flexing. I held the bracket in place and marked the locations for holes for mounting the bracket to the scatter shield. I also marked the bracket for holes for the slave cylinder and then drilled the holes. It works fine.
Tommy
Previously owned EM Cobra
