I guess the easiest way to explain this event to someone is: We want to see which team of 65 cars (import or domestic)scores the most points! (DRAGS the AUTO-X, and the carshow portion.) (not to be confused with the GENERAL CARSHOW!). This event will test the teams capabilites in STOPPING/TURNING/BRAKING and FLATOUT ACCELERATION!! So that part is the team effort. What your STRONG event is, may be your teammate in another classes weakness- got to help each other out.
On top of that, whatever "class" you are in, you also will get to vie for trophies amongst your class: 1/2/3rd place in all events! It will be quite a fun/exciting day all the way around. So........If your car is just better suited for drags, YOUR TEAM STILL NEEDS YOU!! and if your car is better suited for AUTOX, YOUR TEAM ALSO NEEDS YOU! So don't think you can't enter due to (Enter excuse here) because you CAN! No expierence is needed, and there will be cars from BONE STOCK, to highly Modded. Bone stock Imports will run against Bone stock Domestic cars, etc... Whatever car you have in your garage right now, is PERFECT for this event! Register it!
