01-24-2007, 08:51 PM
AZ
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by Bob Broberg SPF667 460BB
Greg, I know you ran that 10.91 before at Speedworld but, that was during a club-rented track event. You may be facing NHRA restrictions at a public event. I hope you are allowed to run under 13.99, which is the quickest time allowed for a topless car without the required safety additions. Including: Taller roll-bar, 5 point base-mounted safety straps, external battery cut-off, scatter shield, fire suit, arm restraints, etc.
AZCobras on morning run that day. I will be at Kruse auction.
Good Luck
AZ Bob
I hope they don't give me a problem. Firebird gives me tech for 10.0 after I display fire jacket, arm restraints, submarine belt, drive shaft loop, scatter shield, battery in stock location, and duck down a couple inches below the little Superformance roll bar. The roll bar is questionable, so I hope Speedworld passes it.
