Old 01-25-2007, 12:44 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
The old saying, "If it's too good to be true, it probably is." always applies. But just in case check out the numbers on the block, heads and manifold. It would be good if you could check out the bottom end, too. If it is a "real" one, buy it, then I'll give you $1,000 for it.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
