Old 01-25-2007, 06:09 PM
Rick Parker's Avatar
Absolutely. Do a test. Temporarily eliminate the PCV valve and drive the car and monitor oil consumption. If it drops, the valve or lack of baffle is at fault. Be sure you have a PCV valve intended for an FE they are internally weighted differently and open or close at different manifold vacuum levels which is controlled by the cam timing.
Rick
