Thread: Oil Temp Sensor
Old 01-27-2007, 01:23 AM
Rob. Smith Rob. Smith is offline
Originally Posted by shelb
Cameron, You Can Bronze Or Silver Solder Brass To Metal. Hope This Info Helps Shelb: Vic
Bronze and silver solder is not like "soft" solder that you are thinking of...Brass welds are stronger than most other welds but the melting temperature is the same as the socket...silver solder is just as good but has a lower melting temp....perfect for brass-to-steel. It is almost fun to silver solder things together. The stuff just "wicks" in and leaves a beautiful finish and the flux washes away with Hot water.
Smithy
