Old 01-29-2007, 06:06 AM
Jimi G's Avatar
Jimi G Jimi G is offline
Originally Posted by Mike Bartlett
So, I was one of the bone heads who ordered the .64 with 3:31 gears. 1800 rpm' at 70 mph doesn't cut it with my motor. Pings at the slightest hill when in 5th.
Has anyone converted there's from .64 to .82? How do you like it? Do it yourself or have a shop do it? How much did it cost?
Thanks.....
Mike
Mike,
The swap can be alittle difficult if you have never been inside of a standard transmission before, as for the parts you can expect to pay somewhere around $500.00. Changing the rear gears to 3.73 will be the cheapest and easiest way to help raise your rpms in 5th. If you can give me some specifics on your car I can see what your rpms will change to with the rear gear change or the 5th gear change in the transmission. I will need to know your rear tire size and I can tell you the difference you will see. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
