Old 01-30-2007, 09:11 AM
SP01715's Avatar
SP01715 SP01715 is offline
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Another question:
I ended up getting a new complete winshield assemby and I am going to replace the glass in the old frame so I have an extra one.
The new assembly that I received has the "Beclawat" plate rivetted on the frame where the center bow clips on top of the frame. With the plate in the way the center bow will not clip on the frame. If I can not find a replacement without the badge I guess the only solutions are to the either grind down the rivets and remove the badge (which you risk damaging the frame) or to not use the center bow.
If I choose to not use the center bow another problem I have is my mirror attaches to it. I looked at putting a dash mounted mirror on the car but access under the dash where the mount goes is a problem.
For those with dash mounted mirrors does anybody know how it attaches (self tapping screws, plate under the dash, through bolted etc...)?
And has anybody grinded the rivets off the frame before? I worry about heat damaging the chrome.
Thanks for any help...
