Old 02-02-2007, 08:48 PM
eschaider's Avatar
eschaider eschaider is online now
The centerline of the crankshaft and the centerline of the pinion should be co-linear if at all possible. If not then as close as possible. You may find you have to make accomodations for manifold/carb combos to achieve a level float bowl. My first choice would be co-linear and machine up an appropriate spacer for the carb to get it level.
Ed
<edit>
Don't worry about the car being loaded unless you are not running an IRS rear.
