Old 02-04-2007, 10:57 AM
Blittleton's Avatar
Blittleton Blittleton is offline
CC Member / Sponsor
Mark,
I would not do it that way!!. First remove you drive shaft and half shafts. Then remove your fuel tank so you can have easy access to you two bolts holding your diff at the aft attachment. Loosen the sway bar at the aft attachment area as well. You will have to remove the one bolt that is attached at the lower front of your diff. Tie up the park brake cable so it is out of your way. Your diff will come out, it is heavy so be careful.
Mark, you don't have to pull the tank, I have done it both ways but it is so much easier if you do. When installing the bolts back in use Red Locktite.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
