Barry,
I assume you do not use the cork gaskets at each end, front/back, of the intake? Also, when checking with the feeler gauge do you check between the intake gasket and manifold or I-gasket and head or both? I assume you do this front and back but also around the top of each head where it meets the intake?
Sounds like you are thorough about this and since I have not installed my brand new Edelbrock heads and intake I want to be sure and do it right.
Thanks.....
Mike
Rubber peelin' gears a jammin'!
