EZ to install
I just put O2 sensors in my exhaust, there is plenty of room, just intall your pipes and then mark a place that works for your car. Its just a wire with a small sensor, ez to place and hide if you want to. You should keep the sensor somewhat close to the engine, I am sure the distance range is in the instructions if you are using an aftermarket setup.
